to EBC, or not to EBC...
Old 01-06-2005, 06:47 PM
awilson40
awilson40's Avatar
Question to EBC, or not to EBC...
that is the question. I really want to move to an electronic controller and I like
the Greddy Profec B spec 2 due to its price, compact size and realtime display.
I have searched a bit and found lots of good info. Anyone have any opinions, good or bad?
Old 01-06-2005, 06:56 PM
theedge
theedge's Avatar
A while back I upgraded to an LBE. Big improvement over stock, faster spool, held boost a lot better, more down low grunt (as in <3k RPM). First few times I ran with it, the turbo screamed
Then I move up to a Greddy Profec A, the one with the fuzzy logic learning. Another big improvement, in spool speed, the works. It has a little LED display as well. Only trick is programming it, it takes some figuring out. Also right now it does this odd thing with opening the wastegate as the car goes from vacuum to boost, but I dont know if this is the Profecs fault or if its just my 213k mile wastegate All in all im very happy with it.
Old 01-06-2005, 08:55 PM
daniel951
daniel951's Avatar
i am in my process of installing my EBC right now. from what i hear i will see great improvents with spool up time and also holding boost to redline of course using a upgraded wastegate.
Old 01-06-2005, 09:21 PM
fast951
fast951's Avatar
I just sent my EBC (Profec-B spec 1, the original) to SpecialTool to try with his Tial WG. I believe it did not make much of a difference when compared to a MBC.. If you can wait till next week, i think he'll be dynoing and he data log boost/rpm so he'll have lots of data to share (if he wishes to do so).
John
Email
www.vitesseracing.com
Old 01-06-2005, 09:39 PM
daniel951
daniel951's Avatar
i will be dynoing soon to see if it made a difference also.
Old 01-06-2005, 10:42 PM
awilson40
awilson40's Avatar
I have to get my wideband installed first, so I have some time. I got in on the Evo GB (please dont call me a traitor...I just couldnt wait). I look fwd to seing some back to back results. I really think I want it for the 'gadget factor'
and to have boost that doesnt change with the temp.
Brian, thanks for the picture. Thats wher I plan to put mine and it looks pretty good there.
Old 01-06-2005, 11:16 PM
awilson40
awilson40's Avatar
Also...can I connect the Profec B spec 2 in dual port mode?
Is there any benefit over single port?
Thanks again
Old 01-07-2005, 12:19 AM
NZ951
NZ951's Avatar
Run dual port Wlison... you have a tial. Best to run it in dual you will get faster response.
Old 01-07-2005, 03:57 AM
shaheed
shaheed's Avatar
i got better spoolup in the lower gears when i switched from a reliaboost to profec-b spec II.
Old 01-07-2005, 08:38 AM
awilson40
awilson40's Avatar
Thanks, I know the older versions have DIP switches to set up dual port or single. But the spec 2 doesnt.
Anyone have a tested diagram for dual port hook up with the spec 2 ?
Old 01-07-2005, 08:53 AM
hally
hally's Avatar
Andrew, whats your k26/8 boost curve look like at present with your AccuBoost?
Old 01-07-2005, 08:55 AM
awilson40
awilson40's Avatar
Its a K26-6 (non S) I hit 16 psi at 3200 rpm falling to about 13 psi by redline
in 3rd gear. It will hold boost longer in 4th gear.
Also... does the Profec B spec2 come on with the ignition, or do you have to remember to turn it on each time?
Old 01-07-2005, 08:56 PM
Duke
Duke's Avatar
You guys with EBC and dual port... do you hook up the side port to the turbo outlet?
Or do you leave it unhooked/to ATM.
Old 01-07-2005, 09:01 PM
NZ951
NZ951's Avatar
Duke, you use a 3-port solenoid. So, with two lines off the banjo, you run one to the side of the WG, and the other into the solenoid, then one from the solenoid to the top of the WG. The EBC then vents through the thrid port. Leaving it unhooked would be effectively running it in single port mode.
Old 01-07-2005, 09:03 PM
daniel951
daniel951's Avatar
from what i understood when someone told me that is both side of the wastegate is hooked up.
Quick Reply: to EBC, or not to EBC...
