Found Brake Fluid leak --How do i fix it
Alright the leak is coming Line on the front of the master cylinder its dripping verry slowly could i just take it apart does it have an oring? it is one of the brake lines not the clutch line it has a large diameter fitting about 2 inches long between the line and MS
The clutch master cylinder? Is it leaking brake fluid over the driver side carpeting?
If so, bad master cylinder, needs to swapped in with a new one. It's a two hour job. It's only a $50 part, but I recommend you replace the slave as well, for it is going to go bad soon as well.
yeah thats wats leaking the proportioning valve thingy lol Thanks special tool, i can see alot of fluid build up over an hour or so i suspect its from the valve to master cylinder connection or valve to line connection or the valve itself .. it makes my car smoke too after i get out after a hard drive white smoke comes out that side of the hood, where the fluid is dripping down onto the heat sheild/turbo etc
anything happen like this before??
Thanks alot guys
Thanks alot guys
