Dyno charts for Reference
just thought i would post my dyno sheets incase anyone was interested. i plan on attending the dyno soon after all the other parts i bought are installed to see the difference between the two.I think the runs were at 13psi and then 14-15 and then 16-17psi or somewhere around that sorry for not having exact boost pressures but next i will for sure with the EBC. Happy boost everyone.
You seem to have two different kinds of a/f curves -- one that looks like APE chips with a big valley of richness between 3 and 4k, and another that seems to get richer as the rpms increase. How are you tuning fuel? Are all those runs done with the same chips?
ya they were all done with the same chip. they were tuned with the arc-2. I am now going to tune with the safcII now. but i think the guy didn't know how to work with the arc-2 so that is why it was messed up. Plenty of power to be made.
When you run that rich (9:01) don't you have the risk of damaging the piston rings because your washing the cylinder walls?
Originally Posted by hosrom_951
You should see better numbers once the a/f ratio is cleaned out through the rpm range though........
daniel: You running H4 lights?
