TPS signal on KLR?
TPS signal on KLR?
Hello
where to get the TPS signal for dataloging at the KLR or DME?
I need the 0-5V signal clear and without to much noise.
Konstantin
Konstantin
Tom has some VERY good right ups on the Zeitronix installation, at the bottom of the page he shows which wires go where (including the TPS):
http://members.rennlist.com/tom86951...nd%20wires.htm
However, im not sure about the 0-5v signals.......
hello
I finaly comected the TPS signal to TEch Edge but I get only 3.5 Volt on WOT.
I thought I should get about 4,7 to 5 Volt when I am on WOT.
Anyone who checked it amd can tell for sure that 3,5 Volt is enough on WOT.
I checked the Throttle body and yes at 3,5Volt the Throttle body is full open at 90 degree.
The car runs like hell but maybe I lose some HP beacause of a wrong signal to DME/ KLR
Konstantin
Konstantin
Konstantin,
I'm logging TPS data to use with my videos, so it was easy to take a quick look at the voltage range from my car, which is running well.
Closed throttle = 0.38Volts
Open throttle = 3.5Volts
The absolute numbers might change very slightly from car to car due to TPS position setting, but its clear from that that the closed to open throttle voltage differential is around 3.1V. It is not a 0-5V signal.
