2,5L/650hp, dream or reality....?
#46
Originally Posted by hosrom_951
Would one be able to convert the 951/944/968 cars into a dry sump?? would it be financially logical to do so?
logical: depends on how much is spent on the engine
#49
1 Post
No to re-hash this, but on the issue of dry sump engines, why not just use the ole American hot-rodding part a la Chevy Z28's of SCCA Trans-Am fame: Windage trays. Sort of acts to baffle the oil pan and keep the yummy black stuff where it belongs.
#50
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
The problem with the 944 oiling system is aeration of the oil. Basically the oil gets whipped up in to a froth by the crank. Oil foam is not a good lubricant.
The oil level in the pan of a 944 is within ½” of the crank, now add in a little lateral force or braking force and the oil hits the crank. Oddly enough the popular Accusump fix will only make this worse as it dumps a couple of extra quarts in to the sump at hot idle.
Dry sumping is the only ‘real’ fix and a done correctly figure a starting costs of $3 to 4k. Of course you could get fancy and spend a bunch more….
