OK now it's getting worse!!!!!!!!!!!!!!!!!!!!!!!!!1
Originally Posted by Darius Juca
I checked the TPS not througly with continuiti meter becouse mine is kaputt but the TPS clicks and seems to be fine...but as nize said it could still be faulty....what would a clogged fuel filter be like..I am getting steady pressure and it drops for a spit second when I rev it but then goes right back up and stabilizes, back to hunting vacuum leaks....would a vacuum leak make my car misfire though???it misfires bad sometimes especially off idle or when I am at a stoplight and try to get going..misfires worst in 1st and 2nd....I am in a bad didnancial situatuon and would hate to buy a new TPS if not neededin idle when NOT in gear the car SOMETimes misfires and stumbles when reved off idle but once up in higher rpm it does fine..unless in gear and boost...
