klr boost sensor problem
Edit, nevermind! I had throttle position!
My klr boost sensor is putting out a constant signal of .45 volts.
does this mean i need a new klr? Or can I reset something? I think I may have shorted the wire (pin 5) by touching it to ground. What would have blown?
We're starting to see a lot of failures in the KLR box with the pressure transducer failing.
Unfortunately, there is no part readily available to repair the KLR box.
gb
gb
