sound file -lindsey 3" with edelbrock rpm muffler
under 3000rpm it's very quiet inside the cabin. actually, it's very quiet even at higher rpm's as long as it's not under full load. the screaming only occurs when you're at WOT. with minimal load it's very quiet, quieter than any other 'performance' muffler i've heard so far.
in the sound clip, the first three gears is what you'd hear in normal everyday driving. well okay, normal everyday driving if you're driving to conserve gas, but you get what i mean.
andrew; that tailpipe looks like it's at least a 4" diameter. is there any reason you went that big? i'm assuming the rest of the exhaust is a 3", or is the rest of your exhaust also 4"?
Its a bolt in cone which slips inside the tailpipe. Seriously makes it as quite as stock, so when I feel like a boy racer I can, when I want a quiet ride its 2 bolts away.
I love that sound. I hope mine sounds that good. I wish someone could fab an exhuast that sounds like one of them new maserati's. Last time I got to drive one, I revved it to about 7500rpm (red line was around 9000 I think) and the sound was so awsome I nearly creamed my pants. Too bad most of that is due to the engine not the exaust but still I wish our 951's could sound like that.
the trick is to design a free-flowing baffle-less muffler that's also quiet, something that the porsche stock muffler does amazingly well by using triple-resonation chambers. it's just too bad the stock muffler is a 2.5" pipe because it's a work of art;
http://www.chaserace.com/exhaust/exhaustautopsies.html
How do you like your AIR splitter? Why get that one over GT?
![](http://members.shaw.ca/rsandor5/graff.jpg)
Originally Posted by nize
any muffler with baffles will be quieter than a non-baffle muffler. conversely, any non-baffle design will always flow better than a similar baffle design.
the trick is to design a free-flowing baffle-less muffler that's also quiet, something that the porsche stock muffler does amazingly well by using triple-resonation chambers. http://www.chaserace.com/exhaust/exhaustautopsies.html
But I want a loud exhaust at times. Other times I want it quiet, hence the TRR muffler choice. Without the bolt in baffle, its a straight through muffler... which is great for performance.
