The winter project has begun (lots o' picts.)
#62
Originally Posted by 9five1
So I have to ask, you've come this far, why not pull the block out of the car, put it on a stand and tackle rings and bearings while you're in there?
#63
Originally Posted by hosrom_951
chapstic951: Since the turbo is out, go for new a/o seperator seals and the rear balance shaft seal as well (this needs the front rollers to come off).......
#65
Originally Posted by chapstic951
One step ahead of you. They just arrived yesterday!!!
Maybe you should add some exhaust wraps for the headers, x-over and downpipe the 'while your in there' list just gets longer
#66
#67
SSSSHHHH....don't tell my fiance that. She will think that I am not putting enough towards the wedding....
Heck go for a cylinder head rebuild while your in there, OH and oil cooler seals, new waterpump, belts, rollers, tensioners, front seals........should i go on
#68
Forgot to add, are you re-using the lifters or new ones? either case, you need to soak them in oil for a few hours before installing them back in, if you are using your old ones, hope you numbered which ones go where
#73
#74
Here is what I have to put in at this point. All new front, top and bottom gaskets and seals. All new water lines and vaccume lines with a fresh complement of SS hose clamps (120 assorted hose clamps from ebay $33). A "new to me" J-boot, replacement spring kit for my rigth rear caliper, oil sepator seals, venturi delete kit, front wheel bearings and front sway bar bushings. Also have a new Autometer boost gauge and A/F meter to mount.
What left to be ordered? Balance, cam, AC and PS belts. The water pump is only 3K miles old. New PS lines. My hope is to get the x-over pipe and x-member I mentioned earlier.
My plans are to send off the cylinder head to be rebuilt. I am highly considereing a Stage I done by LR. Also planning on detailing the engine. I am either going to send the calipers, intake, cam cover, intercooler pipes etc to be powdercoated or use VHT paint if the cost is too much.
I think that is it!!!
#75
You are going to want (A top of my head list)
* The front seal kit
* Balance shaft bearings (if you are going to do the main's)
* Roller and belt kit
* Exhaust seals
* Crush washer's
* Loctite 574 (for girtle, balance shafts, etc)
* Molly Black assembly lube
* Fuel injector seals
* Plugs, wires, cap, rotor.
* Exhaust seals
* Crush washer's
