ENGINE GURUs HELP Pls... Piston "Tolerance Group Code" ???
Originally Posted by Waterguy
Don't mistake book lernin' for real world experience.
Factory Service Manual, page 13-31, "Checking Pistons and Cylinder Bores." They have identical diameters, but Mahle has slightly tighter tolerances for the standard piston sizes. The diameter tolerance for first oversize (100.5 mm) pistons is +/- 0.007 mm from both Mahle and Kolbenschmidt, so I doubt that it is a big deal. ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Second, just a note that page (13-31) is for the NA motors, although the Turbo suplement shows the same numbers as 13-31 does for the Kolbenschmidt. What it doesn't seem to have (or at least I can't find) are the numbers you have for wear limits. Where were you able to find those specs?
Originally Posted by APKhaos
... his rebuild is runnign a few weeks ahead of mine. With some luck, I'll learn from his experience and the wisdom of the board.
Dar951: You really need to get a less common first name in order to keep me from making such embarassing mistakes.
The piston clearance wear limit is on Page 10-02 of the turbo supplement and 10-02a of Volume 1 ("Tolerances and Wear Limits".) Same values for NA and turbo, although it is presented in a more friendly format in volume 1.
The cylinder bore out-of-round wear limit is on page 10-03 of the Turbo supplement and 10-02a of Volume 1 (again, same value for turbos and NA.) Those are the only wear limits i could find that applied to pistons and bores.
It is nice to see you guys doing rebuilds instead of just swapping in used engines. I congratulate you.
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
It is nice to see you guys doing rebuilds instead of just swapping in used engines. I congratulate you. ![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
FWIW, just spoke to Dave at Lindsey Racing who was exceptionally helpful. My head is on its way to Lindsay as soon as the engine is dropped. Dave has a nice array of temptations that make it really hard for us stock class racers to say NO! Its a character test just talking to Dave
![nono](https://rennlist.com/forums/graemlins/nono.gif)
Dar951: You really need to get a less common first name in order to keep me from making such embarassing mistakes. ![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
Thanks a ton for doing my homework for me and posting the references... Very much appreciated.
