Where to get through the firewall
Rocket Scientist
Where can I get through the firewall to run a vac line for a lindsey boost controller? I ran a vac line for my boost gauge through a small hole I made in the wiring boot. Is there a good place to drill a hole or something to get through? Pics? Thanks
behind the battery there is a plug with no wire running through it. the hole that is there is right above the glove box. You have to remove the glove box. Another one is on the drivers side by the fresh air vent under the hood up on a shelf area. There is a rubber grommet that a lot of wiring goes through there. There is also another rubber grommet behind the cam tower. You know where that cork gasket back there always leaks. A lot of wiring goes through there as well. I have used all three mentioned.
