Dyno results Advice please!! I want a Vittesse stage III kit.
Basic Sponsor
Dyno results Advice please!! 2nd UPDATE!!!
dyno
http://stores.ebay.com/Larts-Porsche...0&_sc=1http://
https://www.ebay.com/str/lartsporscheparts
I am VERY suspicious of that afr. Unless Danno dyno tuned your chips for about 100 runs, that curve is PERFECT. It takes a LOT of work to do that.
I am calling a HUGE bull**** on your dyno's wideband readout - their o2 is broken and they gave you a false graph.
Also - what is tracng your boost?
Oh just realzed that they only charged $35 for 3 runs??? No wonder why. I have never seen anythng under $75 for 3 runs - but they are defntely savng money on o2 equpment.
I agree that there is something wrong with the A/F plot. It's to perfect and there should be a leaner spot at 3500 rpm or something which Danno would have dialed in to build boost.
Basic Sponsor
Danno did the first setup a year ago, after that I have used my Innovate LM-1 wideband and the Power perfect unit to fine tune my car. Believe me, It took LONG freaking hours to get the a/f ratio that flat. I was monitoring my boost gauge and wideband throughout the dyno run and my boost was 17 and my a/f ratio was 11.7 -12.1 all the way in my lm-1. In the Lindsey racing instructions Dave advise me to have a 12.3 a/f under boost all the way to red line thats what I have done, is that wrong?
Lart951, Were the 2 runs in your chart for the same car on the same day? If so, why don't they overlap. The areas under the curve are too different from 3000-4500rpm. Did you start the runs at different RPMs, which could have caused the lower run (RED) not to load the engine enough.
Basic Sponsor
The rod and main bearins were replaced 7 months ago also the rings.
compression test was done yesterday
compression 140 in all cyl.
leakdown #1 8% # 2 8% #3 8% #4 %6
Basic Sponsor
They did the leak down test when the engine was cold and they didn't drop any oil inside the chamber either.
I am sure of 2 things. You are running very lean and the a/f chart above is false. If you know how to read a dyno chart you can determined this without an a/f plot. Looking at run 2 the torque build
up between 3200 to 4300 rpm you will notice that your car is struggling to make torque. Notice the jagged edging. A clear indication that you are very lean. You may be as lean as 15:1 . I recommend you find a dyno with a working wide band. Don't put your trust solely on your installed WB unit or a shop that dose not have a state of the art unit in working condition. That turbo should be at 300 to 320 rwhp at that boost level.
UAE Rennlist Ambassador
Do you have a graph of the boost curve? you are surely loosing boost (shimmed WG), and as mentioned above, what does yoru LM-1 read compared to the dyno a/f ratio graphs?
Basic Sponsor
Hi Hussan, no I don't have a graph, but I was wondering if I should try a tial wastegate?
i was making 311rwhp at 13psi with bad a/f with my sfr turbo? I wonder why u are getting such lower #'s u should be at least 300rwhp at the boost level. Over here i get good prices at dyno's runs 60 bucks for a half of hour and i got like 13 runs in at least
