MAF test?
I'm having MAF troubles, I am not getting the correct signal to the MAF tuner so:
I know it's not the wiring as I can see 100% of it, the way I routed it.
So I must believe that the MAF sensors are bad.
Anyone know how to test them?
it's an autoauthority unit.
Is it 0-5 volts?
more voltage = more air coming into the system correct?
TIA
Is it 0-5 volts?
TIA
At idle you should be getting 0.4-0.8Vdc, When you rev it the voltage should increase.
