Who runs 2.5 L with a GT30R?
#31
The difference from standard T04E and a GT30R is.
1- ball bearing ( faster spoolup / less drag on shaft.)
2-Better wheel design. (new tech)
3- read this
http://turbomagazine.com/tech/0405tur_turbotech/
4- You may think this is stupid. But GT turbo have a cool special sound.
Turbine housing doesn't affect compressor performance.
It only affect the power band.
Like a small TH a/r will spool fast and max out kick.
And a big TH a/r will spool later and make more power at top end.
And miss maching a big compressor with a small TH will not make a turbo that is best of both world. If you overspin the turbine and can barelly get the compressor into it power band. The turbo will not make any power.
3- read this
#32
a video how my previus Turbo boosted
http://www.968turbo.de/19bar.AVI
It was in 3rd 4th and 5th gear and I was NOT at WOT. I was running with a stucked wastegate and tried to regulate the boost with my foot.
Konstantin
Konstantin
#35
I am in the process of installing a gt40 compressor ( same trim as the gt35r) In a to4e .63 ar housing. Hopefully I"ll be going to the dyno soon. I just couldn't bring myself to buy a full gt turbo. To much work for me with such limited time. I think my set up will give me 90% to 95% of what a true gt center will give. At a fraction of price. LR is installing 75 mm gt wheels on 2.5 liters. Witch is huge. My turbo should do well.
Your gt30 is about the same size as a 46 trim turbonetics wheel.
#37
#38
Originally Posted by daniel951
did u see alot of gains from the intake manifold. i was thinking about doing the same thing.
#39
Originally Posted by NZ951
What do you mean you have increased the Link boost settings from 5500rpm? You mean set the target boost higher? Have you got a MBC handy?
I dont want to have bigger compressor than I need. My goal is 500 crank hpīs and I want the smallest C to reach that because I prefere a good powerband and fast spoolup. Then the car will be fast!
So I need to know how a GT30 with 55 mm wheel, trim 52 and a 57 mm wheel with trim 56 will spool and if someone here has installed these on our cars!
#40
Hi Corleone,
Regardless of which compressor you change to,
it will definitely increase lag over what you're using
right now due to weight increase & load when boost
begins to build. If you're just running at 19-20psi, you
can offset the lag by milling the head to increase the
compression.
compression.
#41
Originally Posted by J Chen
Hi Corleone,
compression.
compression.
Do anyone of you out there has any experience of the bigger A/R 0.60 house with ported shroud to the GT3071 with the 53/71 mm C-wheel? It seems to be new and is on page 21 in Garrets new Catalog. It would stretch the C-map to the right and maybe this would be enought for me. Then I will keep my good response (same wheel as I have now) and also enought to produce my last 40 hpīs. Anyone? http://www.turbobygarrett.com/turbob.../downloads.jsp
right click and save as
#45
Originally Posted by pk951
Corleone
Don't mean to be rude, it would be meanfull if ran on a dyno instead of estimates!
Of course I will go to a real dyno like "Rototest" (www.rototest.com) that we have in my hometown. But... everything has itīs time and my car hasnīt been ready to do a dyno yet. There are things to be sorted out and now itīs winter here in Sweden.
But relax it will come and then I will show you all the graphs!
