EBC power source?
Rocket Scientist
EBC power source?
Hey,
Ive got an HKS EVC that i wanna install. I was curious where I should get the power source from. Im putting it in the cubie under the radio. Would I want it to be hooked in to the ignition or battery? Also, I am putting in a boost gauge on the a-pillar, where should i find power for that? Thanks
maybe splice off the 12v feed to the radio? there are 2 12v wires to the radio: one of the wires is constant power, but the other only gets power when the ignition's on. that may be your ticket as long as the device doesn't draw too much power. if you do tap off that line, put in a separate fuse for the hks in case the radio shorts out or something
