Optimum max boost for K26/6
Can someone tell me what the optimum max boost level is for a K26/6 turbo?
Can I get dynosheets from someone who has tested on one day several boost settings on one car with a K26/6?
Thanks!
Thanks!
UAE Rennlist Ambassador
Laust was running 25psi boost on his car (not sure if it was a K26/6 or a K26/8 though), but that turbo was WAY in-efficient at those levels and caused him problems??
. Maybe he would pop in and post a dyno or something
I can't seem to find it in the archives but I thought Danno did some testing and found that above 17-18psi it was out of its range and created too much heat to be beneficial.
Rocket Scientist
Optimum so once you get to the point where you turn it up 1 more pound of boost, it isnt as efficient. Meaning that you dont get the same power as you did when you turned it up the last time. I think the K26 loses its effiency at 17psi. That's what I was told by Lindsey Racing.
Frank,
Here's a link to Rennlister's dyno day where there are several of the boost comparisons with the same car/turbo and you can decide for yourself. 17 psi seems like a likely number for the edge of efficiency. Farzaan's Dyno Day While they're charts for K26/8, look at the Steve R. chip comparison at 14.5psi and 16.5psi. Approx. 1 hp gained for each psi of extra boost. Then look at the stock vs. APE chart. Approx. 7 hp gained for each psi of extra boost (11.5-16.5psi). It looks to me like 15-16 is a better target.
