fuel injector wire connection replacement
i noticed in a post afew have said Napa sell a replacment piice for are wiring onto the fuel injectors. Anyone know the part number at NAPA. Danno do you recall the ##
I believe it's NAPA part# 2-18457
This is a complete connector with 6" of wiring attached. You use butt-splices to hook up to stock harness after cutting 6" off.
For a cleaner look, you can get a different bare connector, wiring pins and boot to re-do the stock connector:
![](http://www.napaechlin.com/images/2-18415.gif)
This is a newer design wth a finger-operated spring-clip for easy removal so you don't accidentally yank on the wire and break it where it enters the connector.
connector: 2-18415 older part# 2-17411
terminal-pin with wire attached (2 required): 2-17421
rubber boot: 2-18415
