Turbo upgrade question.
Hi all,
Can anyone tell me it is worth to upgrade from K26/6 to K26/8 turbo
what is advanced and disadvanced about it?
is it direct bolt -on?
88 none S Guru 18Psi, Tial WG, LSD, billet valve and cat back exhaust.( testpipe soon)
I'm looking at 280-300RWHP.
Thanks,
Jim
Thanks,
Jim
Originally Posted by njim3
Hi all,
Thanks,
Jim
Thanks,
Jim
UAE Rennlist Ambassador
An upgrade to a K27/6 would be more recommended than the k26/8 since the #8 would add more lag than the K27 upgrade.
GURU Racing also has some k27 chips
screw the laggy 26/8
the 27/6 is more topend power with the same spool up time.
27/6 > 26/8
advantages - less lag, more top end
disadvantages - mild tweaking to fit
27/6 > 26/8
The one advantage of the K26/8 is that the stock J-boot will fit on it. With the K27, or most of the aftermarket turbos, the inlet is too big for the j-boot to fit. Unless you have a MAF, you'll need to get creative to attach the intake... It is way worth it, but you need to factor it in...
For the JBoot, just hack the end off or is it doable with some silicon transistion hoses? Im looking at a K27/6 and would like to avoid circumsizing my BRANDNEW jboot if its doable
Do a search, some people attached a K27 using an adapter and some cut off some of the j-boot untill it fitted into the K27.
As i mentioned, a K27/6 or a K27/8 would definately need a custom chip if you have the AFM. Doing another search on the #6 vrs the #8 hotside, i remember TonyG saying that the amount of lag the K27/8 has and the advantage of 10-20hp in the upper revs were not worth it.
Both K27's are capable of supporting 320+whp, it's all about the hotside now
K26, either /6 or /8 is a much better match for a 2.5L engine than any k27.
K26/8 is a direct bolt-in where the 26/8 is.
Should go to a dyno and get your fuel mixtures right because the 26/8 makes 35 more Hp
K26 runs in a sweeter spot on the map than a K27, ie, it is much more efficient. The first variable for the compressor is the engine displacment and KKK and Porsche both used K27's on engines closer to 3 liters.
K27 makes lots of pressure inefficiently on a 2.5 liter engine.
