How does the aquamist water injection nozzle fir to the IC pipe?
Anyone know? I am making some new IC pipes and need to know if the have to make provision of a tapped coil or something to fit the nozzle when I go with water later on...
Yes, I moved it to just before the throttle body. Worked ok in the IC end tank though but probably not the best location. My nozzles use a 1/4" NPT boss that I had welded to my IC pipes built by SFR. Its the red line in the pic.
"I believe it difuses the atomization there."
Huh?
B951S,
I don't know why you moved it. Chances are your water/solution will not be vaporized or at least atomized enough in the short distance it takes into the intake manifold log. Therefore it can't turn corners very well, which means more of your water solution could end up in the last two intake runners.
In one of the endtanks is the best.
Huh?
B951S,
