Spun #2 Rod Bearing - Crank ok?
Originally Posted by Dave E
If you spun the bearing you likely send shavings throughout the engine, a teardown and thourough cleaning would be advisable.
Originally Posted by sm
I would say pull the motor as well, and both Ski and jwl could probably give you the steps for doing it quickly.
BTW, were you at the track when the #2 bearing went? What happened?
Good luck...
Good luck...
Next step was to pull the cam tower, and I found 2 bad lifters and a broken valve spring. Changed the lifters, put a newly rebuilt head on it that I had on the bench, and started it up. Knock still there. Pulled the bottom end this past weekend and found the #2 bearing still in place on the journal but in about 6 pieces !! Rod and crank are damaged.... I was very lucky that the rod didn't come through the block. It would have done that had I been driving it hard on the track at the time. Oh well....live and learn and wrench on the 951...
Hey Man
Brad,
Sorry to hear the crank damage is confirmed. So what's the plan...sounds like a pulling party to me! You know the rules-We break it you buy it! Call me if you need a hand. I guess you'll never know what started the OP drop problem, something sure sounds suspect at 70K though, it was barely broken in.
I just finished the Acura today; Ol' Pokey is next in line for a clutch swap; then 4 new struts on the Q45...I just have way too much free time on my hands lately.
Hey Steve, I think the OP problem was caused by the bad bearing not the other way around. I think this car was abused by the previous owner. It was down 2.5 quarts of oil when I got it, if that's any indication...
I have a like-new crank from my donor engine, plus good rods. I'll be swapping the crank, new main bearings, rod bearings, and a rod from the donor engine. Also new rings, clutch kit while I'm in there. I'll let you know when I'm into it again - maybe a reason for a wrenching party.
I have the Loctite 574 on order. Time to get into it....
Hey Man
[QUOTE=brad-cam]Hey Steve, I think the OP problem was caused by the bad bearing not the other way around. I think this car was abused by the previous owner. It was down 2.5 quarts of oil when I got it, if that's any indication...
[QUOTE]
Ohhh....I never heard you say that before...same thing happened to my friend...GF let the oil level get off the stick,
bye-bye #2.
[QUOTE]
bye-bye #2.
Sorry to hear about your problem. I also live in Santa Rosa and if you need another set of hands just let me know. I've also got an engine hoist if you need one. I'd also be fun to check out each other's cars.
Rob
Rob
Brad, let me know if you need any help. I'm sorry I wasn't there with you guys when "opportunity knocked" so to speak. Sorry, couldn't resist that one, but as you can see, I am looking on the bright side. Again, do let me/us know if there's anything we can do to help get your P-car back in service.
Hey Brad ....., sorry to see the bad luck after the Nor-Cal Run. With that nasty lifter tick I was sure you had lifter issues. I guess the bad lifters and broken valve spring masked the rod knock. Let me know if you need any help or advice.. If you need the machine work, EBS in Reno has done all of my previous machine work and were extremely professional and very reasonably priced.
Good luck
Shawn
Good luck
Shawn
Hey guys, thanks for all the support. Very much appreciated !!!!
Rob, I may take you up on that offer to borrow your hoist. That is the only thing keeping me from pulling the engine at this point. Feel free to drop me a PM with your contact info.
I am also looking on the bright side. This is my fall/winter project now, with basically a full rebuild and clutch job. Hooray !
