leaky turbo temp senor
well,with the k27/8 in and having the water pipe mod done,my temp sensor is leaking at the threads.ive tried wrapping it with teflon tape,it work for a little while,but started leaking again.i was wodnering how to deal with this,since theres alot of you with k27s and hybrid turbos.BTW,its the NAPA temp sensor.thanx in advance.
What kind of thread is it?
If it is a NPT (conical) then Teflon paste/tape should work. If it is straight thread then a good aluminum (crush) or copper washer should work.
