Blitz SBC-iD & power meter
1 Post
How did some of you mount the other electronics in your cars without making it look loke crap?
I made a mold out of bondo and got some carbon fiber, laied it on the mold then cut it out to the right size. I didnt use the epoxy resin since this is anything but structural.
the three gauge pod is a pannel of carbon fiber that my buddy had. It is egt, water and oil temp.
here is how I mounted ours, I should take a finished picture of the dash, but this is what I have for now, I realise this is probably of little to know help, but what the hell.
http://www.voytechco.com/dash.jpg
Andrew
Andrew
Originally Posted by fast951
Davinder, at what RPM do you hit 15, 17, 20 and 22psi in 4th gear? I just want to compare your setup to my setup, Stage 3 and soon Profec B (1st gen).
Never checked the 15psi setting but I bet it would come in at or under 3,000rpm.....Nice turbo.
My Install
I originally used purosil for the boost control (Lindsey DPW), but it was expnding under boost causing a spike. It's all steel braided aeroquip now.
HERE
HERE
Originally Posted by RK951
Where do people using the Blitz SBC-ID install the solenoid? The thing is huge. Possible to put in the footwell next to the DME box?
Just to reiterate what's been said before:
Dual Port Wastegate - Set to "WG" mode
Stock or other Single Port - Set to "AC" mode
