Too rich again? Finally fixed Thanks
Basic Sponsor
I decided to increase my boost from 14psi to 16psi, Iam running the Lindsey digital Maf(Pro-M) I was expecting to do a lot adjustements after the increase but the air fuel ratio didn't change that much actually I think iam still too rich from 2200rpm to about 5000rpm, is that real bad beside consuming a lot of gas?
![](https://members.rennlist.com/lart951/afr2.jpg)
Basic Sponsor
Thanks, so what should be an optimal AFR from 2200 to 5000rpm. Any help is appreciated.
Basic Sponsor
I have a SFR stage 1 turbo and, 52lbs injectors. Ok so it's about 12.0.1 when boost hits, I will try to bring it to that ratio later today when i get home.
Thanks a lot.
Thanks a lot.
UAE Rennlist Ambassador
Just looked at the MAFterburner on the Lindsey website, it looks very very sweet and simply 'up and down' to increase/decrease your a/f ratio.........
man......with the amount of gadgets out there today, you REALLY want to change you 'plans' for upgrades
Basic Sponsor
Sam, It's actually the Innovate LM-1 wideband sensor with the Logworks software very easy to use.
http://www.innovatemotorsports.com/
Basic Sponsor
this is the last run after making some adjustments. My question for the experts, am I running too lean in some spots about 5500-5900 rpms, are those spikes dangerous enough to cause detonation?
![](https://members.rennlist.com/lart951/lasttry.jpg)
Basic Sponsor
Thanks, I had named the file for the last run "IGIVEUP", I honestly didn't think it was good. But iam so frigging happy today, after 2 years, 3 blown head gaskets, one broken ring and a engine rebuild, it's finally done. I was going to try to bring the final A/F ratio to 12:0.1 about 6300rpm but if you think it's ok Iam taking my wife to dinner tonigh.
Thanks fellow Rennlisters.
Luis
Luis
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
Lart, do you use the LM1 solely with the hand controller when doing accurate tuning runs, or do you also have it connected to the analog AFR gauge so you can keep a close eye on things whilst driving in general.
I like the accuracy and data logging capabiliy of the hand held unit, but I also want something I can easily monitor when driving hard. I think the LM1 could be for me
Basic Sponsor
For tuning I ussually do the runs with my oldest son and he monitors the LM-1, but for general driving I have a AFR meter bought from Lindsey racing. I just love the simplicity of use of the LM-1. Next i will order the analog unit that connects to the LM-1 for more accurate reference.
Luis
Luis
Basic Sponsor
I have the sensor mounted permanentely in the tail pipe.
