Draining & replacing brake fluid?
1 Post
Should I drain and replace the brake fluid before the upcoming winter storage or right after it comes out of storage in the spring?
I would think after winter if you only did it one or the other. Any of the moisture could get in during the winter compared to if you wait until Spring you won't have any.
Do it after. And don't drain, that air in the system will be a nightmare - just suck out the res and fill with new, and then bleed until new fluid comes out each caliper.
Sam
Sam
