wastegate?
The Deltagate is crap compared to the stock 39mm wastegate; if you want aftermarket, go with a Tial or Profec or HKS wastegate.
"I take it you have a 26/6 then?
I have the 26/8 and can hold about 15psi at full chat. 18psi up to about 5-5.5k"
There's been a couple of people who've tried getting a flat 18psi boost-curve with both a K26/6 and K26/8 using both a GURU and Tial wastegate to no avail. Jason_86_951 tried, as did eclou, Jake951, Timm Baldauf actually blew his K26/8 turbo apart trying. Whereas others with a K26/6 can hold 18psi flat with the 1st generation GURU wastegate.
Aside from the wastegate, you have to make sure your turbo is up to spec and not worn-out. Measure the axial and radial run-out as well as the clearance with the outer housing. I'm trying out a modification to the stock turbo that reduces compressor-wheel clearance with the housing to see if we can't make it more efficient.
Originally Posted by streckfu's951
It compresses the wastegate spring, effectively raising the spring rate so it requires more pressure (boost) to open.
UAE Rennlist Ambassador
Simon: You would not notice 'more power'
You shall notice that the boost holds longer in the upper rpm range.......
If it drops, then it would drop more slowly than an unshimmed would do.
But shimming the wastegate is just a 'bandage', the spring is still the weak link here......
Danno, I know you have been busy but when are you going to update your sight with the new products and prices? I need to figure out how much money I am going to spend over the next year so I have lots to do when I get back.
And if the boost holds longer that also = more power right = car accelerates quicker in the upper rpm range - yes?
Originally Posted by SimonK
Ok what about overboost protection would it kick in or not as a consequence?
Since your holding the same boost but not loosing (or slowly loosing it) at higher rpms, then yes, the car would be faster in higher revs.
Overboost protection is if you have the stock chips/set up.
It comes on at ~12psi, stock is at 11psi, so no overboost protection........
So, if you have a better wastegate (Tial, LR, Guru) and your turbo can hold 11psi to red line (ha, what a joke) then , (compared to a stock car) your car would be faster, since stock cars fall to ~9psi at redline, when you still hold 11psi at redline.
Again, that is IF your turbo (not K26/6 for sure) can hold to redline.
So I guess overboost protection would become an issue if I shim?
This is not first hand info so don't take it as set in stone.
At the international Porsche Weekend last week at Brandshatch I was talking to quite a few people who had fitted Tials. They all said great Wastegate but fed up of it coming lose and it was a bitch to fit in the first place. I have the Lindsey Dual Port which works really well and fits perfectly as it is a factory base unit. I would say that compared to a tial it does seem a bit pricy though as it is basically a rebuilt unit and the Tial is a completely new unit.
The reason I replaced mine was the piston kept on sticking and I had next to no boost. But if you got underneath the car and hit the unit with a blunt instrument you heard it you heard the spring release and you had boost once more!
Unless your wastegate is shot get the Guru chipset 3 bar regulator and the shims. Better bang for buck than just getting a wastegate and you will notice better performance immediately
No I have superchips - boosting at 15PSI.
I THINK (i may be wronge) EBC's come with a boost limit option (you can limit the boost)
Stock WG will never hold 15psi (unless shimmed). You have 15psi chips, make sure you stay there (more boost you'd be running lean, less boost and you'd be running rich).
That is why some MBC's like Accuboost have spike protection, never giving you more boost than what you dial in. There is also a boost safety system, ie if it fails, it would automatically set itself back to stock.
So basically, the WG does NOT give you an overboosting issue, it's what's used to get the boost (a controller).
I don't see any fitment issues with a tial wg when i did mine it took me two hours once the old one was off. About them comming lose you have tighten, after a few heat cycles, and check once a year. Like anythink else on these cars you have to do preventive maintence. If you look at the tial wg it's a stainless steel unit brand new not rebuilt. I have been using it for two years now with no problems.
Rest In Peace Jaak
Cable Guy
Cable Guy
Folks ... I had my stock wastegate rebuilt by Blazsak Percision Motorsports, lower half and used the existing diaphram unit with 3 mm shims and I noticed a big difference with the boost. Click here
He has noticed that all stock wastegates have cracks in the "valve seats" which he repairs as well as other upgrades to the unit. His cost is about $250 CDN. Markus has customers who have managed to get close to 22 psi from the stock unit.
Jaak Lepson
Jaak Lepson
