camber question
Hopefully somebody can help me here... my 18 x10 rears are rubbing on full acceleration with more than one passenger. I saw a thread a week ago about possible negative camber adjusment. Can I do this with a stock suspension setup? If so, what is the best setting to avoid chewing up my tires.
Thanks, Jim
Thanks, Jim
My car was lowered all the way in the rear to compensate for the lowered front with springs... mine rubbed on hard acceleration... a buddy of mine and I raised the rear end a little by adjusting the rear.....there is an article at paragon that expains this...let me get it.... it is pretty simple...you must have a 24mm socket and a 36mm open ended wrench... i had to buy a 36mm open ender for 70 bucks.....thing is huge and heavy....a 36mm socket won't work.... http://www.tech-session.com/kb/index...x_v2&id=62&c=4 of course this would only work if it was lowered this way too....if it is at max height already..(Stock height) then disregard this...LOL Good luck though....
