Wiring kill switch, need answer ASAP
Hey,
The interior is stripped, and so I figure, while I'm in there, install that kill switch I've been wanting to get in there.
After searching the archives, I see info on Pin 20 on the 951 DME. It's a black/grey wire that leads near the fuel pump relay in the fusebox. Should I tap the kill switch in that black/grey wire?
I would REALLY prefer to install the switch to the ground of the fuel pump.
What wire on the dme can I splice a kill switch into to prevent starting the car?
Wire 18 or 35, which powers up the DME. A very COVERT kill switch would be a simple toggle in the rear passenger side compartment, with a jumper wire run to/from either the -/+ wire from the fuel pump. Nobody would ever think of looking there...except for us rennlisters
