Strutbraces
Well, I think that a strut brace should come after you have a proper strut/spring and swaybar setup. They make a lot less difference in handling compared to the others. But there isn't even a correct strut brace for our cars anyway. The only ones I've seen for our cars (I have the Brey-Krause installed by the PO) attach to the top of the strut towers, which effectively turns the front suspension into a parallelogram, causing the top to flex in unison, instead of preventing flex. A correct strut bar, like ones for 911's, is triangulated to prevent flex. But our cars don't have room for that design. Even so, a strut brace does help over no strut brace.
I would say, save your money for sturts/springs and swaybars and then do the strut brace last. I think the biggest improvement that can be felt with a strut brace is for turn-in response on a race track. For the street? Save your money.
Originally Posted by adrial
Why do you say that?
My car was fitted with a CarGraphic strut brace after some suspension mods/stiffening and the difference is there, although not very perceivable. The steering feels more responsive at high motorway speeds (110 mph +).
The strut brace should make steering more responsive, which is why I stated that it helps improve turn-in on the race track, among other things.
You have to push the car pretty hard to feel the difference.
It works good with stiffer swaybars
Lindsey Racing write: 'During hard cornering, the stock front shock towers spread apart causing positive camber which reduces handling performance. The Cambermeister eliminates most of this camber change to maintain the optimum tire patch for maximum cornering ability. Bolts in and out easily in just a few minutes. You'll feel the difference immediately.'
UAE Rennlist Ambassador
Strut braces only aid when comes to hard coernerings. Someone from KLA posted a test done with/without the strut braces on the track (that is why you do not feel any differences on the street i guess)
Here is the price list for the Leda Suspension: http://www.racersedge-inc.com/2004_price_list.htm
I have heard some fitmet issues with the rear dampers/springs for the ledas
Why not try the escort cup : http://www.lindseyracing.com/Merchan...e=944SUSESCORT
You can call Lindsey Racing - they know suspension. They even have the ohlins but they are close to $5,000 - thats how much I paid for my car!!!
