Oil Pressure warning light
I'm in the process of rebuiling my motor because of #2 bearing failure. Because I can't afford to do this again I want to construct a VERY BIG oil pressure warning light that I won't be able to miss. I would assume I could run some leads right off the oil pressure sender, hook it to a relay, battery, and light that would mount on my dash. Anyone ever built something like this? OR, better yet, can I buy something like this?
If you have a wiring diagram and parts list that would be a huge help.
Thanks,
Scott
Thanks,
Scott
