Rim question and help
OK guys, wanna make sure my setup will work before i buy the tires. My question is i want to run 7.5" front rims with 235/40/17 and rear rims with a 9" with 265/40/17 on a 87 944 Turbo. Will the setup work without a fender roll or anything like that?
Should work fine depending on the offset of the wheel.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Just a note: with the proposed tire specifications, your rolling diameter will be larger in the front than the back. If you used 225/45/17 up front you will have the same rolling diameter all around and it will be the same rolling diameter as stock 16' rims.
