Brake related vacuum porblem?
UAE Rennlist Ambassador
While braking (either after of befor full boost) the pedal feels fine (fluid was changed and system bled by specialist).
But, SOMETIMES, the pedal just dies on me, no matter how hard i press on the brakes, stopping is slow. After that everything is fine.
I read on previous posts that there is something that needs to be replaced? the bias valve or something?
Isn't that on the brake booster? does that usually fail? what else could cause the problem?
Could a leaky/bad vacuum accumulator (black can next to battery) be a cause of this?
It is rare that i experience that 'fad' suddenly, but it happens at worst times.
What usually is replaced in the brake system (expect pads/disks/master cylinder and fluid)?
