Fusina Aftermarket Steering Wheel - Hub Adaptor Help - 3" ring mount
Hello. I purchased a Fusina steering wheel at Hershey this year and was told it was an aftermarket wheel off of an early 911. I am attempting to fit this onto my 951. I purchased a Nardi adaptor based on an eBay claim that Fusina steering wheels fit a Nardi/Personal adaptor. The Nardi adaptor did not fit, so I purchased a spacer that converts the Nardi hub to either a nardi or momo hole spacing - neither fits as the ring is too small even though the holes appear to be in the correct position.
The holes are at 12, 2, 4, 6, 8, and 10 o'clock. The space between 12 and 6 o'clock is 3" - does anyone have a wheel like this? Any ideas? Unfortunately, Google has not assisted me in the least so I really your assistance -
Jeremy
Jeremy
I know it's been a long time...did you ever find an adapter? I'm going through the same problem. The Fusina wheel is an 80mm PCD (distance between center of opposing bolts). Nardis are 74mm and Momos are 70mm. I'm have a test adapter made using a Nardi hub (holes are at 1-3-5-7-9-11 o'clock, Fusina is at 12-2-4-6-8-10 o'clock.
That seems to be the only solution for me
