WTB New 951. What year / model is THE ONE?
Originally Posted by hosrom_951
'86 and '87 models used manual tensioners while later models were fitted with spring-type tensioners.
I'll sell ya mine.................
'88 w/ 57,200 on it Satin Black with black interior.....perfect interior/exterior
$20,000
Lindsey Stage II Intercooler
Kokeln hard pipes
Lindsey blow off valve
APE mass flow
B&B cross over pipe
B&B stainless exhaust
Aeroquip fuel lines
Adj fuel pressure regulator
Magnecore wires
VDO fuel pressure gauge
Powerhaus K27/6-7200
Guru 18lb Chips
TurboSmart MBC
Tial 38mm Wastegate
Bored throttle body
MSD Blaster coil
Jet-hot coated exhaust pieces & heat shields
Lightened/balanced OEM Flywheel
KEP Pressure Plate
Cup Disc
BK strut brace
M030 springs/struts
Weltmeister bars
17" Cup I wheels
Brembo cross drilled rotors
Stainless lines
Repco MetalMaster pads
Blaupunkt Reno head unit
Blaupunkt 4100 amp
Blaupunkt seperates F & R
Porsche factory 10-speaker door pannels F & R
Autometer boost gauge
$20,000
Kokeln hard pipes
APE mass flow
B&B cross over pipe
Aeroquip fuel lines
Magnecore wires
Guru 18lb Chips
TurboSmart MBC
Tial 38mm Wastegate
Bored throttle body
MSD Blaster coil
KEP Pressure Plate
Cup Disc
BK strut brace
M030 springs/struts
Weltmeister bars
17" Cup I wheels
Stainless lines
Blaupunkt 4100 amp
