Heat stuck on, Help!
My heat is stuck on. The AC does not work, but when you ajust the tempature dial the air just goes from hot to hotter, is there a quick fix for this, or can i just pull a fuse? Any help would be greatily appriciated. TIA
Shea
Shea
I feel for ya ... As if it isnt hot enough there already .... Jeezz
Good luck
Ed
Good luck
Ed
that picture shows the linkage for the blend-air door, if you look under the dash, about where your right knee is, you will see a small electric motor that adjusts the temp. of the incoming air. When the small white clip breaks, the linkage falls to the fully hot position, the clip is easy to replace, but until you get a new one you could push the link upwards and secure it with a zip tie or a bit of wire. That will at least give you some relief.
