Anyone selling a decent BOV?
UAE Rennlist Ambassador
What is up with people and BOV's?
Our Cars have DIVERTER VALVES, by getting a BOV and venting to the atmosphere.........oh heck..........check ebay!
Originally Posted by hosrom_951
OEM was NOT a BOV (Blow Off Valve), OEM was a Diverter Valve, and the Billet Diverter Valves.
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
~Eyal
P.S. I have very happy with the evo billet unit from paragon, great stuff!
Didnt take long for the new Vitesse kit to blow apart the old stock unit. BTW, I'm aware that it technically is a bypass valve, thanks. After doing a search it seems that a lot of folks have gone aftermarket for these. As I understand, the newer replacement OEM for the 951 is the same as the 993 - is this right?- with a more sturdy metal valve. Seems like that should be sufficient for 15-16 PSI wouldnt it?
If you have a SAAB dealership handy you can pick up part number 0 280 142 108. It's the same as Porsche part 993.110.337.50 which is the 993 part (they're both Bosch parts and fit perfectly). Your local Porsche place will probably quote you for the 993 part since it's an upgrade version of the 951 part with slightly different internals. These are basically stock replacements so I wouldn't use them if you're running more than 15 PSI.
I also have the evo diverter valve. I am extremely happy with it. The valve opens a lot more than the stock one, I noticed a tiny bit of better boost responce with it. I also installed it on a friends car on the dyno it picked up 2hp. But the added piece of mind makes it worth it.
