S4 brake mounting question
When adding S4 brakes to the front of my 87 951, should I remove or trim back the dust shield? It seems like it will interfer with the mounting of the caliper. Thanks Mike
Either way works - trim if you don't plan on making a shield with ducting, otherwise remove and replace with an entire new custom shield with ducting attachment.
Sam
Sam
