Who sells fog light replacement air ducts?
#62
Well, I got mine. All black, pretty simple looking. Very thin FG. Doubt I'll get to messing with them tonight as far as install goes. Sunday most likely.
May have access to camera tomorrow and will try and snap some photos
worth the $$ imho
worth the $$ imho
#64
Ok, I lied, just went an messed around with installing. I think I know how I'll do it. Given I have the bumper off already, I am going to run a bolt straight down through the foglight housing, disect the opening(2-inch circle) in the duct and pop through the far side. So looking from the front all you'll see is a single bolt cutting the circular openning of the duct, slicing it into two semi-circles. Once I secure that way, I can run a bead of black silicone or some other adhesive around the back.
What ya think of that?
#67
Max,
You can buy mine - still in the box.
I need more air volume, and stone protection, so I'm going with some stainless steel mesh.
PM if you want a set for cheaper than the group buy.
