venturi delete kit
There doesnt seem to be any 944 parts on there tho is there?? or didnt i look hard enough?? Does the venturi kit just comprise of 2 hoses or is there more to it than that?? if so does anyone know the sizes of the hoses so i could maybe just source some hose locally
Drive-by provocation guy
"if so does anyone know the sizes of the hoses so i could maybe just source some hose locally"
I was thinking the same thing. I know someone posted before the part numbers of the 2 hoses in a thread a while back.
Hi Guys. The complete idle stabilizer hose kit is 70$ US . It includes the following
1) 2 factory updated idle stabilizer hoses
2) 4 new intake gaskets
3) blue silicone brake booster hose
4) 1 blue silicone hose to go between the aftermarket(or stock) TURBO J pipe and the metal crank case breather pipe.
5)20' of blue silicone vacuum hose with 5 brass T fittings
Hi Myswiss, i have recently replaced all vacuum lines with lindsey racings vacuum kit, any way i could purchase the kit without the vacuum hose and T fittings?? if so at what price including shipping to the uk?? i am looking to get the venturi mess out if there asap as i am having idle problems
Graeme
Graeme
87uk944t. I replied to your PM. Yes we do offer just the updated Idle stabilizer hoses with the blue silicone brake booster hose and 4 new intake manifold gaskets for 46$ plus shipping to the UK. For that I need your complete address.
Steven
Steven
Why delete the venturi tubes and such?
The later cars came with out all those extra tubes, and if the factory felt they were not needed on the later cars, I feel we can go with out them in the earlier cars with out a problem, and the real bonus: You'll have less things that can cause a vac leak when you are done.....
Would it be posible that a vac leak in the "Venturi Nightmare" could appear as if the brake booster was bad?? when it actualy isn't bad?? As, I have lost power to the brakes.
I have had the end fitting of my venturi pull out enough to cause a leak. The end result, though, was that the engine ran rich and brake pressure was a little harder.
With the engine off, grab the vacuum fitting/check valve on the booster. Bend it as if you were going to pull it out. You should hear the vacuum escaping if the check valve and diaphram are good. If not, either the check valve is bad or the diaphram inside the booster is ruptured. If you have vacuum, there is nothing wrong with your booster.
The reason why people update there idle stabilizer hoses, is to simplify things underneath the intake and reduce the chances or stop any vacuum leaks. The older model hoses , were prone to cracking with age and they also had allot more joints, to potentially cause a leak
