Need MBC install instructions
picked up some Huntley chips and a Manual Boost Controller at a local PCA swap meet...does anyone have instructions on how to install the MBC?? I can't find any info on the web or a good previous topic that describes it.
cheers
cheers
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
Run one line from the banjo bolt on the innercooler tube to the inlet side of the MBC. From the outlet side of the MBC, run a line to the top of the wastegate. In doing the above, you will bypass the stock CV. You will need to cap off the J boot where the metal line connects. There is two metal lines under the intake... One connected to the banjo bolt. The other connected to the J pipe. Undo the one to the J boot and cap the J boot.
They call it the "black **** of Death" b/c it is very easy to over boost when adjusting the ****. Once the **** is in the "range" of where you want to be, very small increments can lead to very large changes in boost pressure. Just FYI, make very small adjustments instead of big adjustments.
