Can someone tell me how to get a busted stud out of the wastegate?
I snapped one of the studs. They have come out before no problem but not this time for one of them. I tried the vise grips but it don't won't to turn.
Heat wrench.... Gently heat the area around the broken stud with a soft flame from an oxy-acetylene torch until it is glowing cherry red. Then work the stud back and forth until it loosens.
Don't burn yourself and don't burn down your garage.
gb
gb
I've used MAP gas for this purpose, which seems to work to. Might want to try an overnight soaking with PB Blaster or other penetrant too. I drill (with press preferably, and reverse bit even better) can also work.
Can you get these anywhere? i was just in a Home DEpot and looked while i was there but coudn't find anything. Autoparts store maybe? Does it have to be the kind that doesn't have the threads in the middle of the stud?
