Collecting Cal Smof Info
Does anyone have a Smog II test result from a 951 they could post. The more the better. I am interested in comparing acceptable emissions levels (ppm) for 86, 87, 88 and 89 cars.
Also, if anyone has been sent to a smog-only station because your car falls within the High-Emitter-Profile, please speak up and be sure to include the year of your car. I have heard several 89 owners getting tagged by this, but have not heard of any 86's yet.
From what I can gather, the acceptable levels were slightly higher for 86 cars, compared to 87 - 89, but I would like to confirm with real-world experiences. Thanks.
Location: Albany, CA: celebrating 100 years of independence from Berkeley, CA
Funny you ask -- I just did it on Saturday for a completely stock '88 951S with 97K miles I got two weeks ago, last registered in Utah. This was a test-only station (by choice). I got....
15mph (1600 rpm) (Max/Ave/Meas)
HC: 116 / 31 / 73
CO: 0.74 / 0.10 / 0.23
NO: 791 / 237 / 580
25mph (2532 rpm) (Max/Ave/Meas)
HC: 91 / 20 / 47
CO: 0.62 / 0.09 / 0.27
NO: 730 / 199 / 592
Let me know if you need more info.
HC: 116 / 31 / 73
NO: 791 / 237 / 580
HC: 91 / 20 / 47
NO: 730 / 199 / 592
I've been a high Emitter Profile for both of my cars for the last 3 years. Never failed a test. It's just the year and the type. Heck, smog-only stations don't try to sell you stuff..
Here is mine from last Dec.
86 951 Stock 72k miles
15mph (2426 rpm) (Max/Ave/Meas)
HC: 135 /41 / 77
CO: 0.83 / 0.13 / 0.61
NO: 1136 / 399 / 790
25mph (2432 rpm) (Max/Ave/Meas)
HC: 110 / 29 / 49
CO: 0.63 / 0.11 / 0.16
NO: 966 / 332 / 200
And the other from last week
86 951 Stock 103k miles - but a weak engine
HC: 133 /41 / 84
CO: 0.82 / 0.13 / 0.52
NO: 1125 / 399 / 1109 < - cat is heading south ?
HC: 108 / 29 / 65
CO: 0.62 / 0.11 / 0.18
NO: 955 / 332 / 499
Hmmm, the requirements are creeping down in the last 6 months....
HC: 135 /41 / 77
HC: 110 / 29 / 49
NO: 966 / 332 / 200
HC: 133 /41 / 84
HC: 108 / 29 / 65
NO: 955 / 332 / 499
Here is mine from December 2003
87 951 Stock 73k miles
15mph (1588 rpm) (Max/Ave/Meas)
HC: 116 /31 / 110
CO: 0.74 / 0.10 / 0.37
NO: 791 / 237 / 769
25mph (2397 rpm) (Max/Ave/Meas)
HC: 91 / 20 / 31
CO: 0.62 / 0.09 / 0.07
NO: 730 / 199 / 509
As you can see, I just passed ! This was with stock chips and a brand new O2 sensor. The cooling system was screwed up and it was running very hot at the time too.
HC: 116 /31 / 110
NO: 791 / 237 / 769
HC: 91 / 20 / 31
NO: 730 / 199 / 509
This was done in Feb 2004. My car is a 88 turbo S with new Hi-Flow cat from Lindsey and new Oxegen Sensor. I also used 94 Octane gas and drove a good 30 miles before the tes.
15 Mph: 1553 RPM
HC: Max 116 Measured 20
CO: Max .74 Measured .01
NO: Max 791 Measured 13
25 Mph: 2472 RPM
HC: Max 91 Measured 13
CO: Max .62 Measured .03
NO: Max 730 Measured 728
15 Mph: 1553 RPM
25 Mph: 2472 RPM
Thanks Dan, do you happen to have the gross vehicle weight for each of those vehicles handy? Is the first one heavier for some reason -- trying to figure out why the max numbers are slightly higher for the first car.
If anyone else has results to share, it would be helpful, especially for 86 cars.
HC: 135 /41 / 77
HC: 110 / 29 / 49
NO: 966 / 332 / 200
HC: 133 /41 / 84
HC: 108 / 29 / 65
NO: 955 / 332 / 499
HC: 135 /41 / 77
HC: 110 / 29 / 49
NO: 966 / 332 / 200
HC: 133 /41 / 84
HC: 108 / 29 / 65
NO: 955 / 332 / 499
Interesting thought. I wouldn't think the weight would affect it
These are the numbers on the smog test sheet.
The first one was 3125# (stock weight whatever that is)
Most recient was 3250# (weights 2900#)
My second car is actually lighter. Fiberglass panels, seats, and so on. Weighted in at 2900 empty. I have to think they weigh with the tester in the car.
I'm not following. So do I empty the car of weight or fill it with lead before a test?
I PASSED! After several weekends of work, the car passed with low-flying muted colors.
15MPH: (CO2= 14.2; 02= .4)
HC Limit 135; measured 125
CO Limit .83; measured .40
NOx Limit 1136; measured 1125 (if it were an 87, it would have failed here)
25MPH: (CO2= 14.6; O2=.1)
HC Limit 110; measured 37
CO Limit .63; measured .10
NOx Limit 996; measured 409
Before the test, I replaced the plugs, some rubber hoses, O2 sensor, stock chips, injectors, etc. The only non-stock part was the Huntley turbo -- but I ran the stock J boot (thanks to Danno's tip), airbox, etc. It was over 90 degrees today, which may have added to the NOx. The much lower NOx at 25mph makes me wonder if there is a small vacuum leak, which has lesser impact at higher rpms. I am not too excited about the high NOx at 15mph -- my results would have failed on an 87 car. Guess I should be happy just to have passed...
I have been going through this stuff for the past five years. It is the worst part about this car, in fact I have been a gross polluter 3 times and have always had to go to a test only facility. THe last two times I have barely squeeked by,... the car runs fantastic by the way. Almost all sensors and engine management components have been replaced.
The biggest difference I've ever seen in numbers has been by having all three cells in the cat functioning properly. Usually one part burns out and the corresponding chemistry fails. High running temps are to blame. Some people say get your car hot before you test... well in a 951 dont, it makes the NOX fail. I've never failed on HC production always N0X, just like evryone else who posted. Try not to get it so hot, I know it's not popular but it works.
Run a cat bypass and save your valuable cat for when the time is right... during testing!
H2Opumper, did you end up buying a new cat and, if so, did it bring your NOx down? Everything in my car is pretty much new except for the cat, so I'm not sure what else I'd do to get the NOx down. I'll check for vacuum leaks again, and maybe get get it tested in cooler whether next time. Other than that, the only other thing I can think of is a new cat.
Tom
As it has been explained to me ...that generally on our cars the NOx goes bad first. If you do a search online about the chem involved, you tend to find info supporting this idea. When I replaced the cat from a 951 with 80,000 miles I blew through the test easily. I just redid my motor last year and then had a hell of a time passing again. But to answer your question is that you can have a poorly tuned motor and put a new cat on and clean it up really well, its amazing what a new cat will do especially the new technology cats. Carsound makes a pretty good cat, made by magnaflow, that does a pretty good job with performance also. Good luck next time, I still have another year before the dreaded smog **** test!
If your in Los Angeles, there is a smog place in Burbank that is VERY 951 friendly.
The owner is a young guy who used to own one and loves these cars. If you ask him to run it off the computer he'll do it for you so Sacremento can't see the results. this way you can see where your at and see if he can get it to pass.
very reasonable, friendly porsche mechanic 1/2 mile from there too.
petesautotech.com
Highly recommended
It's a test only center.
going north on I5 exit on alameda in burbank. Go east, go north on Glenoaks 2 blocks and it's on the left hand side.
petesautotech.com
Highly recommended
