Maf
Monkeys Removed by Request
ummm Tom I run 55lb injector's with stock turbo. The chip's he bought are from lindsey they go with the maf kit(I should know I have the same setup). Install your injector's and re tune the car at 16psi you should feel a huge difference in performace in the car.
What are your other mods on the car? Exhaust? wastegate?
wow then there is deffenetly something wrong because you should feel a pretty significant gain on the butt dyno. Given your mods. Let us know how things go after you get your new injector's installed and retuned.
