Clutch Question: NA vs. Turbo
Does anyone know if there is a difference in clutch disk, pressure plate, TO & pilot bearings between a 951 and a NA?
If so, what is it?
TIA,
Scott
If so, what is it?
TIA,
Scott
on the disk and pressure plate, i would think they are different since the price is different. not sure on the other parts. and not sure what the exact difference is on any of the parts. sorry, not much help
Big difference. 225mm. na and 245mm. turbo. Just for starters. They are not interchangeable. Pm me if you want the list of exact detail differences, including clutch cover differences and pressure plate bolt head depth differences.
Every piece is different, including the flywheel and the starter ring gear, as well as what you mentioned (disk, pressure plate and throwout bearing).
Also, don't forget that the clutch release arm and the bell housing are different.
gb
gb
