Zeitronix and TPS sensor
My zeitronix tells me that TPS is 70% when I give full trottle.
Is this right, or should it be 100 TPS when I give full trottle?
Added 2 files that show the logg in 3 gear.
Max TPS 71,
max boost 15.4 with dropping to 11 at high RPM (either a leak or bad turbo I think. Will check this later
A/F also looks god.
Lindsey stage 3 head, dualport WG, VBC, FPR +
3 gear jpg file
Max TPS 71,
A/F also looks god.
3 gear jpg file
UAE Rennlist Ambassador
I believe that is correct, you also got a nice steady a/f ratio, except for running a bit rich before the end. But the boost should hold 15psi all the way with your wastegate, but you ARE running on the k26/8 turbo, which I THINK runs out steam in the higher rpms. But i know that they hold higher boosts.
I believe its the k26/8 also. Are going for a vitesse stage 2 upgrade very soon! Hope the boost will hold to the red line then!
But cant really understand why it doesnt say 100% TPS. I thought that the zt-2 transfered(shows) the same output that the sensor give.
Do you got a zt-2, or others that also show 70/71 TPS?
