Is it Ok that hard carbon is on top of pistons?
I am doing my head gasket and noticed that some of the pistons have a black hard crusty surface on the top. I am assuming this is carbon. Is this good/bad? I imagine it probably affects compression ratio.
John
John
Could cause pre-ignition, if there is quite a bit of build up.
What you can do is take a plastique scaper, and take as much off as you can, then suck out the carbon.
Just an idea.
Just an idea.
UAE Rennlist Ambassador
I think it is normal. I saw BMW engines with under 30K miles, their piston heads were all black and burned (not literally burned). Calculate at LEAST 10+years of running, older deigns blah blah blah. But i would suggest cleaning them.
I forgot to mention, there are these fuel additive brands that actually clean up the combustion chamber using chemicals and crap. That could belp!
These pistons are from my 911 engine rebuild, but you get the idea....
Getting 130K miles of hard carbon out of the ring grooves was a nasty job, but they finished up nicely.
![](http://www.dorkiphus.com/porsche/modules/albums/album37/Pistons_B_A.jpg)
