Danno Help!! Too much Fuel
Hey Danno I have a question for you, I put in your 15psi chips and seem to run REALLY rich when on boost. My boost is at 15psi, I have a aftermarket guage, so what do I do? I would like to adjust it down some without increasing the boost, so where does that leave me? I know you offered me the 18psi chips, say if you get me a set, would it be able to get the right air/fuel then or would I still have to tune? Please let me know ASAP!! I know I have well over 20 rwhp missing because of the HIGH fuel going in. Thanks.
Mike
Mike
a/f guages are useless anyway. even if you do have one. i have an autometer A/F guage, and the only time i can tell how the car is running is under full throttle, and even then, 2/3s of the LEDs are lit up (and thus the reason it is useless). Sense then i have installed the wideband and i get much better values as far as A/F is concerned. so i agree with hosrom, how do you know you are running to much fuel?
Unless if you installed an analog a/f ratio gauge, which shows you (in numbers) the ratio. This is a cheap alternative to the wide band, but not as accurate? LINK has one, should be good.
How do you know you're rich? In the upper-RPMs, the GURU chips will give you 10-15% more fuel than just about all other aftermarket chips. But you also get less in the low-end as well.
With the LED gauges, you only really know the exact air-fuel ratio when it changes from one LED to the next. That borderline transition will pinpoint the AFR at that moment. But when the mixture goes from 11.0:1 (too rich) to 13.0:1 (too lean), it still falls within the width of a single LED. So if it flickers between the 3rd and 4th to the last LED, you know you've got a 13.0:1 mixture and if it flickers between the 3rd and 2nd to last LED, you know you've got a 11.0:1 mixture. But if the 3rd to last LED is fully lit, you have no idea if you're rich or lean or somewhere in between.
