best boost controller
Im debating between going manual or electronic boost controller. I have heard much from the manual ones, is there a general consensus on the which electronic one works best? Im using a turbonetics wastegate with the stock turbo.
Any input will be appreciated
Jpr
Jpr
Depends on what you want to spend.
I think the best MBC's are from Boostscience
The ReliaBoost -2 or the Accuboost With the ceramic ball upgrade
Electronic boost controllers seem like a bit of overkill, tho, I will probably have one someday as I cant leave well enough alone
I have tried a Electronic Boost controller, and a manual boost controller, and now I have everything stock hooked back up with a modified banjo bolt.
The boost controllers are only good if you like screwing around with how much boost you are going to run. I found that I like to set it, and forget it. Besides, changing the banjo bolt is really simple if I every decide to run more boost. Also, do you have the means to modify your air/fuel ratio when you adjust boost? If not, then neither boost controller is right for you.
I have an Apexi Electornic boost controller I would be willing to sell because I decided that the stock system is much better!!
-Patrick Parato
-Patrick Parato
Cool....
I will go to my shop this weekend, pick it up and take some pictures. I will also get the exact model number as well for you guys. I still have the original box.
I was going to post it on E-bay but I would rather sell it here. I will get all this stuff and let you guys know by Monday afternoon. It is in perfect working order and I spent about $700 cdn for it. Not sure how much I want for it yet.
I also have a manual adjustable boost controller that I will sell cheap.
I promise to let you know price and get some pictures available.
-Patrick Parato
P.S. - I also have some Huntley Racing Hardpipes and monster blow off valve I would be willing to sell. MAF not included. Will get pics as well.
-Patrick Parato
Whoops!!!
Sorry guys I messed up!! The boost controller I have is a HKS EVC EZ. Sorry for the confusion. If anybody is still interested in buying it please E_mail -> pparato@certapay.com.
I can send pictures of you E-mail me.
It retails for about $400us. I would be willing to sell it for $190us. It is in perfect working order, I will gaurentee that and refund promptly if you have any problems with it.
Again, sorry for the confusion guys.
Regards,
Patrick Parato
Regards,
Patrick Parato
