Brake and clutch bleed valves - where to get?
I need to replace several bleed valves on my car. I've found the Speed bleeders at Pelican are actually _cheaper_ than the OEM bleed valves. Any reason for that?
Where do I get the bleed valve for the clutch? Is it the same as a brake bleed valve, or is it a different p/n?
Thanks!
Gary.
Thanks!
Gary.
Thanks, it looked similar to me too. I actually have PET, but I haven't been able to find the clutch slave cylinder in there!? I can only find the master...
BTW, the p/n for the brake bleed valves is 930.351.919.00; still don't know if it's the same p/n for the clutch bleeder.
Gary.
Gary.
Gary.
Gary.
I cant check mine ATM, my video card cant support it so its on my bros computer and hes asleep.
Originally posted by theedge
Is it under drivetrain maybe?
Thanks,
Gary.
