Oil pressure warning
Hi guys,
I want to add an extra after marked oil pressure warning light.
Is there any easy take off I can install an extra pressure swich to the engine?
What thread size is the original sender unit. Maybe I could T an adapter in between?
thanks
thanks
![](https://cimg3.ibsrv.net/gimg/rennlist.com-vbulletin/214x332/oil_press_switch_038b04cab39d0da91ad0d65451cb06ab5171a849.jpg)
I think the thread is M18; not sure of the pitch. For the standalone I'm installing the oil temp and pressure sensor is Bosch. Not sure if it will work with the factory DME; but I can give you the pitch and part number tomorrow if you want. Not at home now. Edit: Here's the switch with part number if you want to check it out.
