Looking for Nippondenso 10p15 clutch solenoid/coil
Hello all.. does anyone know where to source a Nippondenso 10p15 clutch solenoid/coil?
Trying to get my AC working. Just replaced the pulley bearing and noticed cracks in the potting on the coil, thought it might be ok, but it is apparently shorting to ground as it blows the number 17 fuse everytime I push the AC button. I can at least remove the relay to get the cooling fan function to work.
Looked around but couldn't pinpoint a coil anywhere, I dont need the clutch and pulley assembly since I just fixed that.
My car is a pre-february 86 951 with the 10p15 compressor. Dont want to buy a new compressor as i will rebuild this one if i need to.
Griffiths doesn't list the coil, only the seals and such.
Any help is appreciated grealty!!
Awesome let me know if you have it and what you would want for it. It seems the PO did some mucking around and there is just electrical tape, no connector. Unplugging the G17 relay allows the cooling fan to run, so I did that until I replace the coil.
